Turbo 3f
I'm going to turbo my 3f that's on straight LPG. I have seen there is a few 2f's done with good results but I can not find any 3f's has anyone done on before? I'm looking for photos of the 2f to get some ideas on building my manifold I have searched but not found much. Where will I get the oil feed from to go into the turbo?
Thanks in advance
On my 2F turbo I added a remote oil filter (I hated the 2f location of the oil filter anyway) and just t'eed off of that.
Other ones I have seen use the oil pressure sender as a source. Then just have it dump directly back into the oil pan.
this is from a thread in the High Desert Cruisers section-
image-jpg.924336
here's the link to the thread...
https://forum.ih8mud.com/threads/project-devil-frog-isaacs-69-fj40.497126/page-9
check this out>>>
Thanks for the reply’s guys i picked up a Nissan RB25 turbo on the weekend should spool super-fast on and the stock waste gate is 7 psi so that should work perfectly. I’m thinking i will make the manifold from scratch with one flange doing both intake and exhaust so i can lower the turbo height to suit the engine bay better and so i can use a good aftermarket dump pipe to suit the turbo.
check this out>>>
It sounds cool and helped me make my mind up to turbo mine. Im rebuilding the hole vehicle now with different cab and chassis same drive line with the turbo now be a fair few months before its going again which sucks as i wont to here it sounding like that..!
Is anyone running a bypass valve on there system? Is there a better style throttle body to use then the stock carbie that's compact with better flow?
