tuffy overhead console and a cb
windy wyoming
so after five or so years, i finally mounted my tuffy overhead. they leave a plug in the bottom of the compartment to run the handset out, but how the heck do you get it down there from the front of the cb??? anyone have a solution?
balls! I wanted to do that! Anyways, the way I figured it is this: You can either drill into that console, and have a hole coming out of the front of the CB (now that I think about it, this wont work, because then the compartment wouldn't open up very well). I would, and am going to, just keep the handset near the CB, as in, keep it up there, and just fab some sort of thing that you can wrap it around, and then just plug it in everytime you are going to use it. That is the only way that I can think of doing it. Tough issue :confused:
yeah, but have you ever seen a cb where the mic plugs in the bottom? i haven't. a small cb mounted in the "u" bracket with a side mount mic would work...come to think of it a front mount might work if it was in the "u" channel, you might be able to run the cable along the side, but my cb slips in like a radio. no room on the side. looks like i'll have to ignore their instructions about closing the compartment when driving.
I just installed my CB in my overhead console. I mounted the CB as far back as I could. It left just enough room for the mike to plug into the front and then run the cord through the hole in the bottom. Changing channels and adjusting the volume is kind of a pain, but it works. My CB has a smaller chassis than a radio though.
