Yesterday I was able to fit the 8" wide Tuffy in my 77 40 with minor modification to the seats and the console. My interior including seats, seat brackets, and tranny shifter are all OEM.
There are two cap nuts on the inside bracket of each seat. I removed these nuts, used a regular nut and cut off the protruding bolt at the nut level. This provides just enough room to wiggle the 8" tuffy into place.
I first mounted the FJ40 bracket that came with the Tuffy. I then placed the console on top and played around with the best console location when taking shifter, console arm rest, etc into consideration. On my 40, in second gear, the shifter is slightly farther back than 4th gear. Don't forget to check reverse shifter location. Do this fitting with the stereo lid open as it will effect the shifter clearance and final placement. None of the pre drilled holes worked for me so I marked and drilled three new ones. Be sure to also consider the cup holder height as there are three sets of holes for attaching it to the console. Be sure to attach the cup holder BEFORE you bolt the console to the bracket.
Fitting the console with seats in helped me find the best location. I removed the driver's seat for final install. I also installed the stereo and dealing with the wiring with the seat removed made it much easier.
Sorry, but I took no pictures. Camera was dead.
Good luck!
Good luck!
