Try again - ABS code 51
On mine, I wiggled the relay and its connector and the problem went away. That was several months ago. Probably a dirty connection.
The relay is on the DS fender, behind the abs pump I think.
I've unplugged and plugged every connection and replaced the fuse for good measure - no change. Where is the pump motor grounded?
Solutions?
My best friend and I both had this code @tromz and we both replaced the ABS pumps and it cured this ABS code. Fairly easy to change. Bleeding is the worst part. I changed the master cylinder while I was in there. $60 for a new Asian MC. Hope this helps.
Jason
