Trunk is stuck
Denver CO
Hey all,
This was never a problem or even showed the potential to be a problem, but I went to open the lower part of my trunk (the bit without the window) and the lever worked and the trunk door moved an inch but is stuck. It seems something is a bit sticky or the lever stopped working all of a sudden.
Thoughts?
Thanks
EDIT: Never saw the little unlock lock button. Gotta love a silly mistake. Someone had locked the trunk without me knowing.
Did it move an inch on both sides or just one?
if just one you just need to lube The locking pin. You can WD40 it from inside until you get the tailgate released and then lube it properly with grease.
If both sides are moving an inch....no idea
