Trunk and Hood not flush
Las Vegas, NV
Real close to buying an inexpensive, but rust free '94 LC. Hopefully in due time I will be contributing instead of abusing the knowledge base here. The hood and trunk on the one I'm looking at don't quite close flush (hood on both sides, trunk on the right side only. I've searched, and can't find any quick fixes for either aside from adjusting the rubber stops on the hood. I always suspect a collision/bent frame, but assuming the Carfax is clean, is this something that can be adjusted out, or is it pretty much a case of bent door/hood? Thanks again for any help.
Open the hood and rear hatch to see if the hinges are contacting the body where the tell tail factory marks are at. There is some adjustability. While you are there look at both, hood and hatch, closely for deformation. There are other 80's out there to consider also.
Maybe @KWalkerM owned it previously and took it over some sweet jumps!
