Well, just a small annoying issue with the truck. For a month or so, after a 5 minute drive to a long drive, as soon as I turn off the ignition, the truck will not immediately restart. It requires a 3-5 minute wait before it will restart. Starter is strong and cranks, but sounds "dry" . I do not smell any fuel from flooding during this process, but I don't think that occurs with EFI. Here are the several steps my mechanic and I have taken after searching several treads here.
1. Spark Plugs, good
2. Plug Wires in good shape
3. Distributor Cap and lower portion in good shape, also conducted voltage test, within allowable range. Voltage also tested on coil, passed test.
4.I replaced ingnitor and coil with spares on hand, still have same issue.
5.Fuel Pump in good shape as well as battery.
6. Replaced EFI fuse. In engine bay. Big Round One Top/Left
Not examined yet are ECU, and some searches mentioned wiring harness as a possible suspect. Another 91 FJ80 was in the shop at the same time, and they are trying to source the wiring harness, cheap. Can there be other components of the ignition or fuel system that could be suspect?
Just waiting for it to get worst, not so bad around town, but don't want same issues out in desert. Any Comments... Am I on the right track? Or way off...Much Thanks
I will report back.
Just had to ask, you never know
