Troubleshooting elockers
Oregon
The elockers on my 80 have never worked for me. The PO said he hadn't used them in over 10 years. I get the blinking light, but they wont engage. I have tried excersizing them, but that hasn't worked. I figured I needed to disassemble the actuators and clean them up, so I finally pulled the front and opened it up, clean as a whistle, as you can see in the pics, it looks like it just came form the factory floor. So, now I am thinking ECU problems. While I had the front actuator off, I put the volt meter on the plug at the diff and looked for 12v and got nothing, but then it occurred to me, after everything was bolted back up, that I had tested for voltage with the tcase in 4-hi, so I am thinking I need to retest.
I am thinking it would be easier to test at the ECU, but I am not sure which wires coming out of the box provide 12v to the actuator. Can anbpdy provide a wire diagram of the ECU, possibly with some interpretation, as I am not real sharp on my electrical.
i recently took my rear apart because i was having the same problems as you.
it was totally clean (my truck must have been a mall queen in japan)
i took the motor apart and put it back together and it magically started working.
give that a try, maybe a contact is out of wack or something
The rear actuator
Here are some pictures of the rear actuator. I went ahead and dissembled and reassembled as ForealBoreal suggested. I used Raven Tai's write up to make sure the drive gear and the shaft were in proper relation.
The shift fork moved freely and I could lock the diff by moving the shift fork by hand with the actuator removed. I got the actuator to work on the bench with direct twelve volts.
Put everything back together and still no lockers, just blinking lights.:confused:
BTW, those pictures are from before I cleaned the internals!
I didn't get to test for voltage at the actuator, because my courtesy lights ran my battery down, and well, I was sure my rear elocker was going to work. :doh:
I did test at the 4-wheel drive computer and this is what I got:
with
T-case in 4-lo and diff switch to FF RR:
GRN-rd: intermittent 12+V
RD-bl: constant 12+V
PNK-bl: constant 12+V
GR-bl: constant 12+V
BL-wht: constant 10.5V
WHT: constant 12+V
switch to RR:
WHT: constant 12+V
Still working on interpreting this. KLF's link is helpful, but a factory EWD would be nice.
I just got the FSM for an early christmas present. :) I will go consult that.
have you tried the "drive in a gravel area doing slow figure 8's" yet?
I'm in Eugene, if you are close I could be bribed :beer: to take a look, I also have the EWD. It sounds like you are savvy enough to get this on your own though.
:cheers:
and also; search here for this topic- there are a multitude of threads (and may be in the FAQ) on this very subject.
Thanks Tblume. I have tried the slow figure eight's in gravel for about five minutes. Nothing but blinking lights.
I'm in Jefferson, about an hour north of you. I just took a quick look at the FSM, wished I had that thing when I started. With the FSM I should be able to troubleshoot this.
I am open to grabbing a beer anytime you are up this way, or I am down that way. :beer: I don't have any big projects planned, but if you need a hand with any big projects, let me know. What happened to your FJ55? I would like to pick up a pig one of these days.
The FSM directs you to bench test the actuators using your heater relay in the circuit. I just supplied unfused, unrelayed, direct 12V from my starting battery in my FJ60 to the actuator to test it. Would this screw anything up? It didn't seem to? but I did have to really mash the test wires down on the battery posts, to get the actuator working.
Also, I noticed that the drive motor was very tight. I had trouble turning the worm gear with my fingers when the motor cover was installed. I noticed an adjusting screw at the end of this worm gear, but it was staked into place.
Maybe too tight?
I will look closer at the rest of the system using the FSM, before I dive back into the actuators, but I thought I would just throw that out there.
along with figure 8s i also try throwing it in neutral while coming out of an 8, or after a stop and letting it backup a few feet. sometimes when the gear has engaged the fork, but the sleeve hasnt lined up, taking the load off the spider gears by going to neutral helps things line up.
hopefully cleaning and rebuilding the actuator helps you get things working again...
forgot to ask you if you actually tried to activate the locker while the actuator was pulled? if the actuator is OK, then you should see the gear spin momentarily while you turned the dial, and spin again when you switched back to the off position.
Jefferson State Cruiser- North prize!!
Thanks Tblume. I have tried the slow figure eight's in gravel for about five minutes. Nothing but blinking lights. while doing the fig-8 blinky light deal is your center diff locked/light on? my cdl position switch was corroded and after cleaning the FF and RR started working
I am open to grabbing a beer anytime you are up this way, or I am down that way. :beer: I don't have any big projects planned, but if you need a hand with any big projects, let me know. What happened to your FJ55? I would like to pick up a pig one of these days. cool, I'm gathering parts to do a full brake job, sometime next month if you want to see that go down. '55 story is a long one. It was the orange and white flavor (tribute text color, get it?:p)
The FSM directs you to bench test the actuators using your heater relay in the circuit. I just supplied unfused, unrelayed, direct 12V from my starting battery in my FJ60 to the actuator to test it. Would this screw anything up? It didn't seem to? but I did have to really mash the test wires down on the battery posts, to get the actuator working. should be fine
Maybe too tight? probably just right, as clean as your actuators were I'd bet on the CDL signal at this point
I bet you get this licked today, good luck and Merry Christmas! contact info PM sent, will be passing your neck o' the woods next week a couple times.
Do you hear the motors running when you turn the switch? You diffidently can hear them under the truck. Also, next time you have them off, sounds like you plan to do that again, leave them plugged in and have someone turn the switch and see if they actuate.
Also when you are trying to engage them you are in 4 low, right? Sounds like you know that.
Mine were both used and look to be in no where as good a shape as yours and seems like they lock when I just look at the dial.
No, I haven't been able to hear the actuators.
Yes, I have been trying in 4-Lo.
I haven't put in a CDL lock switch. Everything is completely stock on this rig.
I like the idea of the CDL signal as the suspect. I am going to wait until I have a full day to tackle this and do some other PM. With the FSM I should be able to diagnose this.
So is there any dash light or anything to indicate it is in 4-Lo?
you should have a third icon where your diff locks are blinking, of the center of the drivetrain- I think it goes solid immediately, and on the left side of the cluster you should see the ABS light go solid indicating 'no ABS'
merry christmas!
Sounds like the culprit may be your CDL actuator on the center differential. If your not getting CDL light and ABS lights on you can't lock the lockers.
merry christmas!
Yes, No ABS and something else, amber.
Correct me if I'm wrong, but doesn't doing the pin 7 mod completely eliminate the CDL switch from the equation?
I have lockers!!
It was the CDL indicator switch, as Tblume suggested. I pulled this switch, it tested bad. I sprayed some carb cleaner worked the switch ~30 times, sprayed some silicone in there and work it again 30x, finally some contact cleaner, and that seemed to clean it up. Tested good.
I put it in 4-Lo and looked for the CDL indicator light and nothing. :crybaby:
:idea:Then I remembered reading about someone just shifting back and forth between 4-hi and lo, so I did that, and at about the 20th time, I heard finally heard a click at the diff relay, and then indicator light on the dash, then ABS light. ah ha! I worked the transfer back between hi and lo several more times, then went for the rear diff...bingo! And the front...bam!
I guess the indicator switch needed a little more exercising after being installed. The PO never used 4-lo by the looks of it.
Took it for some testing in a gravel lot, and man these things are like tanks when there are all locked up. The only thing I noticed was that the front and rear diff locks didn't want to unlock at first. I used the throw it into neutral method and they unlocked with a click. I exercised the whole system locking and unlocking it over and over, as I played in the gravel, and they are working great.
Thanks everybody! I learned a lot about the lockers, thanks to this forum.
:beer:
thats something i need to try. i hope it works with my front locker !
I need to look a little closer, but I think my speed sensor on the transfer isn't working.
Aren't the diffs supposed to automatically unlock when the vehicle exceeds 5mph? I pushed it close to 10mph a couple of times just to test, and nothing happened.
Do you have to be over 5mph for a certain amount of time?
I can't wait until I actually need to use these. Looks like I will be taking the family to play in the snow soon.
