trouble starting
I have a 68 fj40 that I've been working on all winter and was hoping to have running by now but I can't get her started. I added a weber 38mm, dual battery system, hei ignition, mean green starter, a rebuilt alternator, headers, dual fuel tanks, and rebuilt the 3spd. Now i'm trying to get her on the road and can't get her to run. When the ignition is engaged it will fire up and sounds good but the second I release the key, it dies fast. Like it's starving of everything. I've set the timing at top dead center and from the way it sounds when the ignition is engaged it's almost perfect. I set the baseline on the carb, tried to adjust it a little, and then reset baseline. Nothing seemed to do anything. I checked the fuel and it looked a little rusty, so I switched tanks and cycled fresh through it and that didn't do anything. The moment I release the ignition it dies fast and i'm stumped at what to do. Any ideas would be greatly appreciated.
Thanks
anddan89
Welcome.
Grab a test light, and with the key in the on or run position, make sure that you have 12v to the power wire to the coil...
You have fuel in the truck, correct? ;) and it is to the carb? :)
Good luck!
-Steve
anddan89 said:
When the ignition is engaged it will fire up and sounds good but the second I release the key, it dies fast. anddan89
It sounds like the classic symptoms for a bad ballast resistor, but 1) early cruisers didn't have them and 2) you don't need one for a HEI distributor. Does the hot wire for the distributor come off of the starter motor solenoid? If so, this would explain it, but it isn't correct. You want to use the black yellow stripe wire that comes from the switch. It could also be a bad ignition switch, but I would verify this with a meter or test light before replacing it.
