while trying to adapt the FJ60 box with factory slipshaft to my stock steering column shaft I have run into a problem.
The end of the slipshaft is 36-spline. I first assumed it was 5/8" 36 spline as that is a common size, and close to what the caliper read when measuring the splines; that was too small. I then tried a 3/4"-36 spline joint, that was too large, but just barely. The local race shop has no other joints in between. I have found one other joint that is in between 5/8" and 3/4" but I would rather not spend another $60 plus shipping just to eliminate another possibility.
Perhaps the splined section is metric, but this I kind of doubt considering most splines elsewhere on the truck are compatible with domestic splines of the same count (tranny input/output, transfer input gear are all compatible with GM).
This joint is to connect the stock FJ60 slipshaft to the .75" smooth shaft coming out of the factory steering column. I did not anticipate this kind of difficulty locating the right joint.
As always, any help is appreciated.
