Transmission
Woodstock, GA
When draining the oil out of my stock 3 speed I noticed there were alot of metal particals on the drain plug. Even two small metal chips. Should I be concerned about this? Who knows the last time this oil was changed by the PO. It shifts fine (for a three speed that is ;) )
I guess you need to define "small", and after that, get a transmission guy to tell you if it's bad.
I don't think that I've ever drained the transmission/transfer/differential oil that I didn't see some amount of metal shavings on the magnetic plug. The plug's doing what it's supposed to do which is to collect such things. I'd drive it until the transmission falls apart and then decide whether to upgrade to a 4 speed or 5 speed.
In my opinion, the 3 speed is not worth spending any money on.
Good Luck,
James
Good Luck,
James
That is what I figured. Thanks. And man did it stink!
3 speed, shavings, no worries. Pretty much a given with a non-synchro 1st gear. My buddy Jeff has a saying every time one of our crew misses the shift [which is fairly common] 'Grind me a little too, butcherman'
