Transmission
mdjohnsen said:
I plan on throwing my transimission into the Atlantic Ocean because its loud. I suppose it's a good loud but jeez....it whines alot....just like me.
Howdy! So what tranny are you running? The original 3 speed can get sort of loud after a lot of miles, and the original transfer case gets really loud when it gets old. Usually the needle bearings eat up the shaft on the idler gear in the transfer case. That causes the idler to sit crooked against the other two gears and the teeth are not running square on each other. Rebuild the transfer case and you will probably loose over half the noise. John
SM465..
You drive a cruiser. things are never going to be quiet..
