Transmission weirdness
Delburne, Alberta
The truck in question is a 1992 HDJ81, meaning right hand drive, 1hdt diesel, with the A442F. Other fun facts are FF rear diff with discs, and oem electric winch which works well. Truck is stock on 31's with exception of sliders and rear bumper, small coil spacers, egt and boost guages, and some tuning for a little more power. I've owned this vehicle for a little under a year after saving it from a previous neglectful owner, I feel it has alot higher mileage than odometer shows after having worked on it a fair bit to catch up with long overdue maintenance issues. That being said, after a bit of tlc its been serving me well as a DD and occasional tow rig.
Did something strange last weekend though, I had fired it up to move it across the yard and into the shop for my weekly once over, drove across the yard, went to reverse, and nothing happend. No go. Tried all forward gear positions same thing. Had someone else move shifter to verify linkage, tried transfer case shifter, cdl button. Couldnt make anything obviously happen beyond park function and what seemed to be neutral. So, towed it into the shop to be looked at later that day, somewhat baffled. I've been driving the truck to work for months now without an issue. Hauled home two large loads of firewood on a flat deck trailer without issue weeks before.
Trans fluid looks good, when I first got the truck I ran a pail of new stuff through it, slowly by means of pulling a cooler line at the rad and running truck for a few seconds at a time, then shutting off and topping up pan, then running again until new clean fluid was visible.
Later that day I started truck again to see what would happen, and trans worked perfectly once again. I've been driving it to work all week.
A temporary loss of hydraulic pressure? But more importantly, why? Has anyone else had a similar experience? Also, can anyone say conclusively if this trans has the shift solenoids I've read about in recent searches?
I had a similar issue with a 90 HDJ81.
Maybe coincidence but check rear lights and wiring.
