Transmission Uhoh
14 mins from the bus
Short version CV joint busted...
Front drive shaft jumped up and busted the inlet coupling going into the tranny. As you can see, I have the hose disconnected, but the coupling doesn't want to cooperate. It is loose & I can move it back & forth, but I am afraid to turn it.
Lay it on me!
Nevermind, the coupling is just alot softer than the casing & it was well boogered up in there. A little more fiddlin w/ it & it came out.
& yes I realize that I just used boogered & fiddlin both in a two sentence post.
Make that twice in three.
What happened? Did you pop a U joint?
