transmission speed sensor - need help locating it
Columbus OH
I have no speedo or odometer, replaced the transfer case speed sensor after getting code P0500 Speed Sensor A. Having trouble finding good specific info. Read about gauge cluster issues and how the cluster generates the digital signal for the computer. I sent the gauge cluster to Tanin Auto Electronix, they tested the cluster and all is a-ok. Recommended changing transmission speed sensor.
I know it is an A343F, and I can see a couple of plugs going into the front end by the bellhousing, and a couple more back toward the tailhousing. From stuff I have read the speed sensor is at the tail housing end, but which plug is the sensor? What does it look like?
Google images shows a lot of pics of Toyota transmissions, but I can't find the detail I need. I have read many threads on this site, but they all end before actually showing exactly which plug is the sensor.
It comes off the left rear side of the transmission.
I posted a couple of pics in this thread: https://forum.ih8mud.com/index.php?threads/818436/
Cool thank you for the help sir! That jives with the clues that I have been able to find, that I need to replace the sensor toward the rear of the transmission.
I never did find good information about this, but on eBay they are selling "the speed sensor that makes your speedometer work again" so I bought one. I'll post up how it works out. No part number on the auction, but I don't know what the part number is supposed to be anyway. It is supposedly the automatic transmission output shaft speed sensor.
I'm the kind of person that likes to know how things work down to the bare metal, I work as an engineer. But I am not having good luck finding detailed info on this truck so far.
Just wondering if you checked all your fuses? Only the sensor is a really rare part to fail. Look for INST or CLUS something along those lines. Sometimes it can be something as simple as a dash light shorting out to cause the fuse to blow.
Here you go: Straight from the Toyota horse's mouth....
Thank you for the info guys! Much appreciated. Tomorrow I am working on the LX, but I don't think my new sensor will be here yet. I need to pull the AHC stuff off of the frame on the passenger side so that I can install the Metaltech sliders :)
I still have my cluster out, so I may try to check the signal with my voltmeter. I hadn't really thought of a fuse being the issue, but it won't hurt to check. Thanks again!
Also I do have an ODB2 code reader box now, it includes a live diagnostic feed mode. If anyone has any tips on using it to troubleshoot the speed signal issue, feel free to pipe up :) So far it has just picked up the P0500 code.
