Transmission solenoid problem
Beaumont, texas
while tackling the the solenoid fix, the head of the bolt broke off in the valve case. Has anybody had to deal with this, and if so what’s the best route to extract the remaining bolt. I know that the most logical way to do this is use an easy out, but I’m nervous that I might crack the valve casing. Any and all recommendations are appreciated.
The bolt in question is the actual bolt that fixes the solenoid to the valve box.
Left hand cobalt bit might work since the head snapped off. Usually for internal bolts the head of the bolt carries most of the tension, once that is popped off then the stub is removed easily.. I say internal because you don't have to deal with corrosion as much as an external bolt would require.
O'Reilly Auto Parts sells a very nice left-handed drill bit screw extractor kit with bits that are actually sharp and hold their edge. I have used mine many times.
