transmission slip ?
Long Island
I just bought my first 80 (kind-of by accident) and have alot to learn and fix, but love my new truck, best 4x4 i ever owned. I have a 93 w175k w/factory lockers which is real solid, but it makes this weird sort-of rpm spike when the tranny shifts from 2nd to 3rd. It is real quick and gentle, but odd. Buddy in tranny shop called it a "flare" and said it's no cause for alarm, but I'm not convinced. Anybody have this same issue? Is it "normal" for these trannies? Is there a way to fix it?
Maybe drop the pan, clean the filter, and replace all fluid with Dexron, or adjust the kickdown cable?? Seems like I read on mud about some service bulletins about the trannies for certain years. Wait a bit for the experts to chime in with specific recommendations.
If what he says doesn't help you might find some to ask about the transmission if it has bands that can be adjusted like the older US trannies. Otherwise the clutches may be worn out and you need an overhaul. If thats the case just drive it easy during that shift and it will last a long time anyway.
I just adjusted my kick down cable yesterday and what a difference! No more slipping or clunking transmission. This seriously takes 5 minutes and a 14mm wrench.
I'll check out a rodney flush, but gotta admit when it comes to high mileage Auto Trannys i have always been real hesitant to do a flush. Seems like the risk of dislodging built up gunk and causing more problems might out weigh the potential benefits. If it don't stink, don't stir it. Guess I need to do more research. Thanks to all, this forum is absolutely invaluable to a newbie like me.
Avoid flushing a high mileage tranny.
Adjust the cable. that is the very first thing I do with ANY Cruiser that has an automatic.
Mark..
