Does anyone have any info, or pics of the PTO used on stock transmission?
Thanks.
Vic
Thanks To all for the response,i had several of those old 4 speeds with the side pto cover ,as mark said the gears wont work.the bolt pattern is the same as a pile of pto,s i have but no gear to line up with.you would have to use an sm 420 or 465 to get that option.then you would need a forward and reverse pto unless your farming or running a hydraulic unit.good luck
