Transmission problems ! Please help
florida
Hello all , I have a 96 fj80 and when I'm ready to drive I'm having trouble accelarating till I hit 30 after that it shifts fine can it be the solenoid ' my over drive light turns on and off when I'm driving as well it's flickering twice I believe , po753 is the code that I'm getting as well please help thanks ,,,, al
2nd button depressed? If so it will not start out in 1st gear but 2nd. Does it accelerate normally if you manually shift through the gears?
I wouldnt have thought the overdrive light would affect your takeoff only top end speed. Sounds like bad wiring or a bad earth to the dash light. My OD light doesnt work at all but the lockout button works fine
Your take off issue (need more info, what gear is it in?) can you manually shift ok?
Disconnect the tranny harness on the side of the trans box down near the starter. Manually shift through gears. If all works fine then its an electrical issue, possibly your NSS barrel plug above the starter which commonly corrodes out.
Yes as you stated your 1-2 solenoid could be stuck shut . this happened to me.
There are a few places to get these . I got my set for a good price (Borg Warner type) from a place there in the states Called 'cobra transmissions' I'm pretty sure there are vendors on here too that could source for you if you get stuck
