Hello,
79 FJ 40. I'm doing a 350 conversion. I used an AA adapter to mate the 350 to stock 4 speed tranny. I put the shifter into the transmission this weekend and it moves left to right like it's in neutral, however I can't get it to go into gear. The Transfer case shifts fine.
Not sure it matters but I have a new clutch master and slave cylinder mounted and the fork in the bell housing is moving when I depress the clutch. (I'm saying I'm not sure this matter because I had another FJ 40 which when the engine was off, you could easily shift the tran. into and out of gear easily without the clutch.
I'm hoping it's something such as the tranny was in gear and in a bind when taken out and when rocked a little it will free up. (I don't have a drive shaft right now so I can't test.
In the meantime I curious as to whether anybody has any guess as to what might wrong?
Thanks.
Thanks.
