Transmission lean?
South Africa
Is this lean angle how the transmission sit in a 60 series normally or do the engine pull it up in the one side when mounted? I'm doing a conversion and need to know if I should acount for the lean on my adapter?
Yes it is normal for that year.
the 3F bellhousing has this designed into it, it matches the crossmember/mount and the shifter stalk all take this into account
along with the throwout arm/ clutch fork
the rotation also helps with front shaft clearance
Thank you!
