Transmission leak
Sheridan, WY
Hi all. Lots of searching but no joy. My transmission (A343F) is hemorrhaging fluid from the front of the case. Shifts are smooth and everything runs fine so long as I keep the fluid level in shape. But distributing about 1 quart/100 miles around town and trail.
Input shaft seal? Something else?
If input shaft, is this something that can be tackled by someone with reasonable mechanical skills? Special tools? Parts and/or other 'while you're in there's'?
Any and all input is appreciated. Thanks folks!
BTW - cruiser is a 1997, triple locked with limited armor, no lift (yet)
2 seals on the front side the outer hoisnig oil pump seal (large o-ring) and the torque converter /oil pump input shaft seal (kind of like an axle shaft seal press in)
Years ago, you guys used to export to us in the UK something called 'WYNNS' transmission sealer and conditioner. Never seen anything like it, every auto trans we used it on stopped leaking! Unsure if it still about?
To answer the question, yes the trans needs to come out.
regards
Dave
