Transmission Issues still not resolved
Formulaonehd
NWZ - The storm is here
Pilbara Region Western Australia
Hi all
Hate to start a new thread but I'm starting to get a tad down on the fact my transmission might have a serious issue.
I have been on other threads regarding the kick down cable and NSS barrel plug.
SO where am I at? Well the 93 4.5 with the A442F (only 149,000kms) has just come back from the garage after having some jobs done on her, including the rewiring of the NSS barrel plus which was completely corroded out. I now have all my dash lights working except Neutral. Not sure but it does shift in neutral no problems... Mechanic said fluid and oil levels are fine.
My reverse has a pause of 2 seconds (particularly when cold) and then the car rocks and clunks into reverse. Put her in 'D' and she takes off in 1st ok then skips to 3rd where she stays and never kicks up to 4th. Before I had the NSS plug rewired it did the exact same thing except it went from 1st to 4th. When you give it gas it never kicks down gears but will change down under braking and stopping.
I can change manually without any real problems. I have tried adjusting the kick down cable but what is odd is there is nearly an inch or two of slack and im running out of thread on the inner bolt (i'll post pics below). My throttle cable has some slack maybe a cm or two.... What I don't understand is if slack cables can cause the nasty shift into reverse (I wouldn't think so).
Last thing I should mention is the car sat dormant for several years before I purchased. Could this be a band issue, or someone mentioned the links??
Any help before I dive into expensive options would be really good.
The IH8MUD community has saved my ass more times than I can remember!!
Have you disconnected the harness from the trans and tried shifting manually minus any electronic input? If this works well then your problem is with the solenoids. Your issue sounds similar to the one I had when I bought my 93 with a rats nest in the air filter which told me it had sat somewhere for a while.
If it turns out you need a solenoid or two, I can help with finding those much cheaper than dealership prices.
No havent disconnected it. I'm starting to think it may be solenoids too!
Could you describe the issues you were having? Im in Aus so i'll probably have to order them online (toyota here will charge me $$$$$).
Is replacing the solenoids a big job??
Mine had a delay in the first to second shift. Sometimes it would barely move from a start in "D" but if I dropped it into "1" and got rolling and then shifted it up to "D" it was fine and other times it would not go into reverse. I also has a 40" rpm flare between shifts which I took care of by adjusting the throttle cable to the trans.
80-Series Tech
I'm new at pasting in links so I hope this worked. It's my thread and posts #57 and #64 contain info you may be interested in.
That did not work. The title of the thread is "Reconstruction after rollover and other stuff I do to my 93".
