There is always something and I am a bit frustrated but anyway to my point.
First, please read all the information, don't jump into suggestions before reading all the information. I am trying to be as informative as possible.
My truck has been leaving a small puddle of transmission fluid on the passenger seat side and a bit behind it when parked overnight (obviously not literately under the pass seat but on the road).
It was not doing it in the summer, to give you reference time wise.
When I was working on the front axle rebuilt I have noticed the leak. But I think it got somewhat worse.
The overnight leak size it about .5 oz. It will not continuously leak. When I was working on the truck, it was on stands for a month. It only leaked the first day or two. So it needs the engine running to leak.
I am not missing trans fluid, not yet and I have not filled it in months. Maybe it was overfilled in the last service.
With engine running, I don't see continues leak ,or drip I should say.
when I was under the truck and noticed it, it looks like it is dripping from the rubber hose connection of the heating tubes that goes into the rear heater. I know that the heating tubes are carrying coolant fluid. But believe that the leak is somewhat up stream and it travels on those pipes and and drip from the lowest point which is the soft connection between the hard line. The location is right above, I think between, the two catalytic converters.
Anyone has a clue or have seen this kind of a leak before?
TIA
TIA
