This weekend my wife and I went and camped at the Oregon sand dunes, and while driving around the dunes I noticed the vehicle feeling extremely underpowered, I let off the throttle and then my trans A/T temp light came on and I noticed I had forgot to switch back to 4lo after running back to town. I put the vehicle into neutral to cool down, light went out quickly, I put it into 4lo and drove around fine until I gave it some beans to go up a hill. It started climbing up normal and just at the crest of the hill slowed to a stop and would not move forward at all. Usually 4lo, in lo you will just spin the tires and sink.
Now back on flat ground and off the sand the vehicle will not go into "low" or 1st gear. It will also (assuming by feel) not go into second gear. If you put it into drive I'm pretty sure it is starting in 3rd gear and once up to speed shifts fine into over drive.
If I am moving slowly ~10mph and downshift to second no shift changes, bit if I go into 1st (lo) you can feel the drive train binding and it shutters to a stop. If you push the throttle you get no forward movement in "lo" (in 4lo, or 4hi)
*Fluid is still pink, not burnt smelling or low on fluid. Year is a 95
I have not seen a thread with any similar issues.
I made it back home thankfully without needing a tow and plan on just getting a used transmission, I'm just wondering if anyone has experienced a similar failure.
