Transmission Electrical plug issue help
Texas
Website
www.peopleschoiceins.com
I have a 9 wire female plug that goes into the passenger side of the transmission. When I removed the plug to aid in removing the engine I noticed the plug was melted around 2 of the connecting pins.
I got a new blank plug from CDan, however the connecting pins themselves are covered in melted plastic and at least one of the larger ones is broken off. It looks like there is simply too much carnage to use the same harness.
I now think there is a good chance the part it plugs into may be damaged as well. I plan on checking it as best I can with a mirror tonight.
Does anyone know of a source of this part of the wiring harness?
Does anyone know a way to repair it?
Thanks,
DTaylor
you can get stubs from CDan. They are basically a short length of wire with the proper crimp on the end of it. You splice them into the harness and plug them into the connector.
Yah, I just got off the horn with him. It looks like this will be the best way to go. It also appears this 9 pin plug goes to the nuetral safety switch. I'll likely wind up replacing it as well.
