Transmission cooler lines
Coopersburg Pa
After 24 years of faithful east coast service, my hard lines on my 94 are starting to leak. I've been giving the truck a full go over since I bought it in May with 109k. After almost 7,000 miles over the summer driving around back and dirt roads in the north east (and a front axle rebuild) it's time to tackle some unknown issues.
I see two different ways to do this; 1, go OE Toyota all the way (local dealer told me over $500 for pipes and hoses) or 2, carefully tuck transmission hose along the frame rail and run it that way. I don't like to cut corners, especially since the truck will be making a trip to Myrtle Beach in early November with my wife and 2 year old daughter. We've done well all summer but I don't want to push my luck!
Right now I'm trying to keep costs to a minimum, so I'm leaning towards the rubber line option. Any input?
I bet you can get some used ones in decent condition for a reasonable price. Check the classifieds to see if anyone is parting these out.
Good point. Ever change the lines? I can't quite see where they terminate into the trans, might be my angle from the ground.
I've changed the hoses but not the lines. I imagine it would take a bit of work to change the lines but nothing too crazy. I'd recommend changing all of the hoses at the same time (bulk Gates transmission cooler hose from NAPA) and investigate the junction block near the battery tray for corrosion in case it needs replaced as well.
Thanks. I plan on replacing everything while I am in there. The stupid PHH is also on my "do it now" list.
The junction block that goes through the firewall? I have an extra one from my old 93 but this truck does not have that style cooler.
I'm referring to the junction near the transmission cooler in front of the battery tray. If your lines are corroded then there's a good chance this junction is also. @Red Merle recently had his torn apart and probably has a photo or two.
That's the setup I have^
I bypassed the junctions through the frame and bypassed the radiator. Doesn't get very cold here in the south. Went to the hydraulic place next to my work and bought 8ft of hose. Took about 4ft each section, maybe an hour tops. Think it was like $13 for the hose
The junction you highlighted was pretty rusty on mine and I had even purchased a new one from Mr. T but I decided to just soak it in acid overnight and then prime and paint it once it was back to being clean metal. Saved me $58 and it works fine.
Remember there is partsouq.com and amayama.com for OEM stuff.
