Transmission Change
I have a 99 LC with 62k miles on it that I just bought for my DD. The only thing that really bothers me is the (automatic) 4 speed tranny. Anything above 65 and it really starts to feel like the RPM's are pushing it.. With speeds of 70-80 mph (and you don't get pulled over) in Georgia, it would help to have a 5 speed. Anyone ever change theirs out for a 5 speed? Is it even possible?
Hoser brought this up a while ago. But I think with the probable high cost of the newer 5spd tranny and the unknown regarding if/how the ECU would talk to the new tranny it would be a complicated and/or expensive ordeal.
Personally, I don't think 70-80mph on stock gearing/tire size is pushing it in terms of RPMs. If you want lower highway gearing, the cheapest way would be to up the tire size.
The 5sp auto itself doesn't cost that much but making it work (electronically) might be a headache and still unknown. Some discussion here.
At 116 mph the truck was stopped by the limiter not the redline.
33" tires will improve highway gearing (a little) but you pay on the starts and stop (a little).
A 5 or 6 speed tranny does not guarantee lower RPM at tha same speed. The 5th in the 5-speed tranny can have the same final ratio, or lower, or higher than the 4th in the 4-speed one.
Anyway, at 80 mph your engine is running at around 2600 RPM, which is just a relaxed pace.
True but in the case of the A750F 5 speed auto we get here, it has a lower 1st gear and higher top gear than the A343F, 4 speed.
