Transmission and Dashboard
Help with Dashboard, electrical and some alerts
  • Electrical system
    Votes: 0 0.0%
  • Tune up
    Votes: 0 0.0%
  • Total voters
Hi
I hope everybody is doing good, I have a few questions and will like to see if someone can help me.
I have TLC 1997.
I noticed a few things in the dashboard.
A- The light of the Gears light D and 2 at the same time, when I drove today it seem it get stuck in 2 but it lights both gears. After a stop and go then it mark the D and it seem that the gears where shift properly but when it mark both it seem that Im driving in D.
b- The ABS light is always on not sure if this is normal
c- oil pressure light is on and the gauges of the oil pressure seems to go up when I accelarate and down when I stop no idea if this should be work like this, I just replace all the fluids and oil
d- The back window on the drivers side stop working. it when down but doesnt come back up I check the fuse box near the break pedal and also clean the main power window switch.
Can someone please provide me with what can i do.
Regards,
B) could be a bad wheel speed sensor, could be an unplugged sensor, could be a break in the wiring along the axle and control arms. Could be an unplugged ABS pump. You should be able to get the codes for the issue.
C) Your oil pressure gauge should rise when driving and lower when idling, this is normal operation. The oil light being on could mean that your oil pressure sensor is bad or not connected, you have low oil, or like my cruiser some jackwagon broke off the neck of the oil level sensor on the left side of the engine and it's stuck in the plug and not attached.
D) use the switch on the door and try pulling the window up by hand when using the switch to roll it up. Chances are the regulator is burned up from old window runs might need a new window motor and new window runs. If that doesn't work you can try to use the master switch and pull up. If your other windows work you might try swapping a know. Good window switch with that window switch and try to roll it up. If the switch at that door is no good it can cause the circuit to quit functioning...happened on mine also.
As for A) that could be a bad switch or a short in the dash wiring several other things. Hard to tell what might cause that.
