Transfercase Seals?
I have a new clutch being put into my 73 FJ40, and while the transmissions is out I am going to have new gaskets put in. It was also suggested that I swap out the transfer case seals at the same time, but having a hard time deciphering which seals I need. It is just an Input and and Output seal correct?
Thanks all.
@Ezra
Here's an illustration of the transfer case. It may be a challenge to replace the three seals shown (transfer input shaft at transmission, transfer outputs, front and rear) without a number of gaskets, which ends up leading to an overhaul.
@Ezra
Thanks, I was confused about the two output shaft seals. Assumed there was only one output shaft.
I am having the gaskets replaced as well.
Thanks for the info.
