I recently installed a 2" body lift on my 97 and have run into a problem with the transfercase shifter not going or staying in Low range. I new this would be an issue ahead of time and this is what I need to know. There is a round shaft about 1/2 inch in diameter that comes out of the top of the transfercase and then transitions into the larger diameter black bodied shaft that you see sticking through the leather boot. Is the larger shaft just screwed onto the smaller shaft? I tried removing it with a pipe wrench but didn't want to reef on it too much in case they are not just threaded together. I know as a last resort I can heat the smaller of the two shafts and bend it to a more virticle angle.
