Transfer Case Whine
Alabama
In 3rd and 4th gear in low range 2 and 4 wheel drive I have a whine in my case. Which bearing is worn causing this noise? I have a stock 4 speed and case. I intend to just keep using her for a year or so until I pony up for an Orion but I'd still like to know which bearing is causing the noise.
Maybe none.
Low range has a different ratio so it makes a different noise. The fact that it is noticable at high speeds (3rd and 4th) in low suggests that if there is a problem, it is wear on the low range output gear bushing because this gear is always turning on the shaft in hi range which makes it wear faster. The wear allows the gear to tilt slightly on the shaft so the teeth don't mesh ideally. Since you don't spend much time in low range and 3rd or 4th, I would just live with it until something more significant comes up.
