- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
Well, now all is back in place and the linkage is real smooth except I can see that steel shift rod won't go into the second position (the seat for the ball bearing). I think at this point the problem is in the transfer case which hasn't spun for a long time, does that make sense? Or else I just need to turn the engine on so I can put it in gear a bit and see if the shifter will slide.
Yes, try spinning the frt driveshaft by hand while a helper inside yanks the lever back into 4WD.
What are your thoughts on the internal rubber ring where the steel shift rod goes in? I didn't change it, nor the fibrous cork colored ring gasket that sits right above it. I noticed they were both a little damaged but....I crossed my fingers and used 'em anyways.
It will probably be fine. Leaks in that area are generally less a concern than keeping it lubed enough to prevent galvanic corrosion.
I'm thinking of just cutting a piece of metal or rubber myself for the bell housing. What do you think? Seems easy enough and no one can see it anyway!
I think the easiest thing is to call toyota, order the right piece, and snap it into place. But I'm weird that way.
This part:
31121-60021 Boot, clutch vent $20.86
