Here are the notes from a previous post. https://forum.ih8mud.com/showthread.php?t=17871
I thought my problem was in the front passenger side. I replaced the right front wheel bearing and u-bolts and the popping remains. After looking into it more, it sounds like it is in the transfer case.
The popping was only happened during take-off from a stop and slightly when shifting gears. Yesterday, I removed the rear drive shaft , greased the u-joints, greased the drive shaft, tightend the output nut on the transfer case output shaft and the rear differential nut. Now the popping is a little louder and more frequent than before. It doesn't make any noises after the initial pop and it drives very smooth at all speeds.
I have read on other posts that it could be the u-joints, output shaft in the transfer case, the bearings in the rear differentials, or an over greased drive shaft. The transfer case was rebuilt less that 1000 miles ago and there was a period that I had to roll start it probably 15 times because of a weak battery and no money.( don't know it this could have caused anything.)
Any help narrowing this problem down would be greatly appreciated!
jb
78' fj40
jb
78' fj40
