I've had an All-Pro one since they came out with it way back in... 2001 I think? The bellcrank bracket was about to rot off my horsecollar in my old '84 so I couldn't keep the OEM e-brake, it was really my only choice.
I also think it's the only choice if you have RDB, like I do, which is why it's on my current truck.
I disagree with some of your comments above, it works fine for hill starting, no difference. It has not caused my t-case to leak. The caliper is from a golf cart, and works well. I've never come close to hitting the disc on anything, the mechanism and my BudBuilt skidplate completely protect it.
The pad on my caliper is getting pretty worn, so I'll have to do something about it before I re-install again. As I understand it, you can't replace just the pad, you have to replace the entire caliper. My disc is also pretty rusty now. Actually my entire brake is rusty, I can't seem to keep it from rusting. By the time I replace the caliper and rotor, plus spend all the time sanding and painting it again (3rd time), I may just be better off getting a new one.
It's a pain to install. The rotor goes on the back side of the outlet flange, so you have to pull the flange off (new seal and stake nut required), then pry off the dust shield ring. Wrench access on all the bolts is a challenge. But it does hold well once you get it properly adjusted so it clamps well but doesn't rub on the rotor when released.
When applied, the truck won't sit dead still, you can still rock the truck back and forth due to the slop in the driveline behind the t-case. And, if you lift one rear tire up in the air, it's no longer a brake, the other tire just spins (unless you can lock the rear diff).
