transfer case out put?
Can any one tell me if I change the transfer case out put seals (front and rear) if i have to preload the bearings and what is the spec? I want to try this before i end up pulling the transfer case and giving it a proper rebuild.
You can change the seals by just draining (this step is important :D), pulling the drive shafts, pulling the cotter pin and castle nut, then pull off the flanges. The seals are right there and you can yank them out and carefully install new ones. Put back together in reverse order, and make sure to goop some RTV on the output splines and under the castle nuts to prevent leakage down the splines.
The mainshaft bearing preload is set via shim(s) between the rear output housing (speedo gear housing) and the case. You won't get that far just replacing the seals so there's no need to worry about it unless you've got noticeable play in the shaft. In which case, you're due for bearings...
I don't have the preload specs with me, but it has to be checked with everything put together including the ebrake, so it's kind of a pain if you actually have to mess with it. It seems like everybody I've talked to about it has had the same experience I had, which is that re-using the original shims with new bearings comes out just fine.
HTH,
Eric
