Transfer case leaking from ebrake output shaft
Toronto
1974 FJ40 4-speed.
I had the transmission and transfer case rebuilt and am attempting to install it now. I filled the transmission case, but when I filled the transfer case, fluid pours out of the output shaft at the ebrake bracket. The ebrake shaft was coated in rtv (that was a PIA to get off to get to the washer!) Is the transfer case not sealed without the ebrake shaft intalled? Is it proper for the ebrake shaft to seal the transfer case with rtv?
Thanks!
Hard to tell if your seal is placed correctly in the housing. I would start there. Means you have to drain it. It is common to put some rtv on the output shaft before sliding the brake housing back in. I would use red RTV. Not black.
Yep - all normal. The e brake drum must be installed and torqued to spec with the staked nut on the end of the output shaft to maintain a proper seal.
It is not uncommon to coat the splines in RTV prior to sliding the drum on to take up any little gaps that would allow oil to sneak down the spline. Probably wasn’t done from the factory but after 40+ years there is often some wear.
Further - the sealing surface on the drum that rides on the output shaft seal can often develop a groove and allow oil seepage into the emergency brake. There are speedy-sleeves that enable you to restore that sealing surface and prevent leaks.
Others have even machined out the lip on the speedometer housing where the rear seal rides to allow for two seals to be run. Search “mudrak rear seal modification” and you should get some details. This gives you a double sealing surface, and also has at least one seal riding on fresh, ungrooved metal.
Yes, the smooth part of the drum is also the inner surface for the seal which resides in the speedo cable gear housing. The RTV is a previous attempt to deal with imperfections on the brake drum and output shaft spline.
hi
thirst cheak the seal
but
when i look your picture
it's seams that the shaft of your drum brake has not a surface very plane ( bearing contact)
in this case the oil can go between internal and external teeth and in this case your leak arrive
you have also two washers , one thin and one thick behind the clamping nut
the thin is against the oil leak
It's easier to fill the transmission and t-case after the install. You need to install the p - brake cable and shoe assembly before the drum goes on. Then you can torque the nut and stake, or install the cotter pin as appropriate.
If the p - brake cable has been completely removed from the rig you can do all this assembly on the bench.
Do it yourself:
Or check with Mudrak, Georg at Hybrids, Poser, or www.marksoffroad.net
$60 exchange. Mark’s Off Road PN 090-88AS
Hi DIck, thanks for responding. When I got the transmission/transfer back from the rebuilder it was already leaking residual fluid from the PTO cover, so before wrestling it back installed only to find more leaks (and I would then be sending it back the rebuilder) I decided to fill it and check for more leaks.
I am having a bear of a time getting the transmission mated to the engine, I just cant seem to get enough clearance between the crossmember and the input shaft getting into the clutch. The drum fouls the crossmember and I have a new speedo cable to install anyway (the old one was not leaking) so I removed the cable and drum along with all the shifting brackets to make it easier to manuver. I didnt realize the brake drum was a seal keeping transfer case fluid in...today will drop the rear engine mounts to try again and get the transmission installed.
the RTV is from a fresh rebuild by a transmission shop that said they know landcruisrs...The transmission did not leak before the rebuild.
Is the transmission and transfer case uniquely difficult to fit back in early 4-speed models? I heard that the 3-speeds are challenging to fit a 4-speed transmission in there. I squeezed an SM420 into a '73 doing it by mating the gear boxes on the truck, before. Is it easier to just reinstall the H42 transmission, then the transfer case?
I wouldn’t say it’s any more or less difficult that any other manual transmission installation - but I’ve never found it to be an easy process on any vehicle.
You have to precisely align 200lb of oily metal in a confined space and stab it through a ring (throw out bearing), a splined hole (clutch) and another even smaller ring (pilot bearing). It is probably one of my least activities under a vehicle. I’d almost rather pull the whole engine, install it outside the truck and throw the whole thing back in as a unit.
I just bought M12 fine pitch bolts and cut the heads off with a chopsaw. I plan to use them to guide the top ears on the transmission into the bellhousing, then bolt the lower ears, then remove the studs and bolt properly.
The problem that I saw with, specifically, replacement of the engine with the gear boxes is that it was weighted too far to the passenger side upon removal. I'd fear that the bellhousing mount would slide off before I could bolt it in.
