Transfer case leak need advice
Los Angeles, CA
I have this slow leak coming from the transfer case on the photos below. The parking brake drum is dry. Trying to find the source, I cleaned the area last night with brake cleaner. Waiting to see where it’s coming from. It collects at that bolt in the photos. Anyone experience a leak in that exact spot? What’s the culprit? Thanks everyone
Easy fix.
While you're at it, get the double seal housing from valley hybrids, service the parking brake and the speedo cable seals. I just went through mine, so far so good.
I believe there's a gasket there and/or rtv that'll seal those two adjoining faces.
Have you tried just to’snug’ up the fastener? I’d hate to disassemble for a minor leak.
Like they say with these old girls…if they ain’t leakin’ there ain’t no oil in them…. 🤣🤣🤣😵‍💫
I actually snugged them up a bit and most of the bolts there went another 1/8 of a turn. I then cleaned the area with brake cleaner. Going to monitor and see if it helps. You are absolutely right about these old gals leaking.
