transfer case help...
Wisconsin
so i have a fully rebuilt sm465 tranny i was wondering what all you cruiser heads out there thought. should ikeep it and make it work for my 2F motor or should i sell it and use that money and get a 4speed out of a later LC? i have a 3speed right now with no syncro from 2nd to 1st so it makes it hard for wheeling at time let me know what you guys think or even maybe a differnt set up
thanks everyone who looks!
What do you do with your truck? The low of the SM465 is pretty sweet for offroading. I have a Toyota 4 speed tranny and t-case out of a 76 if you want to go that route.
well um, you realize that toy 4speed, 3speed, and 465 all have the same final drive ratio of 1:1 right?
no OD for any of these trannies. If you wheel the answer is simple given the options... 465
nv4500 is the 5speed version of 465, very spendy and long, would not be cost effect speaking from a gas standpoint. h55 is the 5 speed version of the toy, and it has a pretty deep first, once again not extremely available or cheep.
crazylandcruiser said:
well i do lots of wheeling but i also drive it not a daily driver but i do drive it alot during the summer and thr three speed is killing me on gas milage i justr want something with an overdrive so tell me what you think
If fuel efficiency is your goal none of these transmissions will make you happy. In fact, no transmission will make you happy. This is a big heavy machine with lousy aerodynamics. It's going to burn lots of fuel.
My rec-if it meets your needs as it is now, minus the fuel economy issue, then don't change it. If you want to make a better off roader, then the SM465 will be sweet. If you just want more comfortable gearing for normal use, with a slightly lower low then you have now, do the Toyota 4 speed.
