Transfer case cover part number
Boise, Idaho
I was under the rig greasing it and discovered that at some point along the way, someone left off the small cover that goes on the end of the transfer case. It covers up a wire bundle and terminal block or something. I can't find it on the on line schematics yet. Can anyone tell me the part number?
Your description either needs a picture or more specificity.
Do either of these diagrammatics help?
Does this help? I can try to do a better job of photography if needed.
Looks like number 36336 or whatever is cut off the side of the first diagram. It wraps around the front ujoint to catch much of the grease up there, and protects some of the transfer case mechanisms. Needs to be removed for driveshaft lube.. probably why it’s missing.
Also the 91674-80814 bolts to hold it on. Think there are 5, maybe 4.
Finally had some time to dig into the parts diagram.
I think you need 36336-60030, looks to be the same on 07-current 200s.
Odd thing is the system is saying only 3 of the bolts. Just checked.. mine has 4.
If anyone needs these (or any factory splash shields) PM me. I have a pile of these things from installs and have just been throwing them in the metal salvage bin.
Sent you a PM on this.
