Transfer Case Bearing Question
Federal Way, WA
i have a late model 4 speed case. The front output bearing is bad. Since I am taking it apart to replace that bearing I might as well replace the needle bearing too.
I have read a few posts about how hard that job is. I would like to start with a pilot bearing puller.
Question: how much space is behind the needle bearing shell? Will a standard pilot bearing puller jaw fit in there?
Second question, what is the bearing OD? I have not received my parts yet.
Thanks
I'm assuming you mean the small roller bearing up inside the mainshaft itself? I've found the best way is the carefully cut them out with a high speed burr grinder.
This is a 3 speed transfer case mainshaft but you get the idea. It's far too small to get a puller in there.
I used this on my needle bearing on my 3 speed TC - the smallest puller size:
Slide Hammer and Bearing Puller Set 5 Pc
It took a while to get it out; but I finally got it. You might try using penetrating oil on the bearing for a few days before you try to pull it.
The above tool is pretty useful. I used to pull the pilot bearing when I replaced the clutch - on my 40, 60 and Tacoma.
Good luck
That is the exact tool I was thinking of buying.
The case is installed and I was not planning on removing it. Being able to swap the bearing in place is a must or I will leave it alone.
I don't hear any whine while driving in 2wd only 4wd. I think the needle bearing is probably worn but still serviceable. However if I am already there...
Good luck
I worked the issue Saturday. The old needle bearing was in perfect condition. I left it in and just replaced the large roller bearing. What a difference. The output turns so smoothly now and no more side play. Should work perfectly when I get it back on the road.
Thanks for the advice, but I am glad I didn't need it in the situation. Especially since I don't think I could have fit a slide hammer up in there.
Lucky, and a smart move to leave it!! I had such a hard time getting mine out I ended up having to replace the shaft. I never could get any separation from the bearing race and the shaft. It seemed like it had completely rusted in place. Not surprising, considering the front output was completely packed with mud.
