I got a gauge ready to be installed and a in-line sender with a T fitting and nipples. The previuos posts were a little unclear as to where the best location for this sender would be. Can anyone advise?
Find the 2 fluid lines that come out the passenger side of your tranny. The forward one is the output and is where you want to take your temp reading from. Follow that hard line until it turns to rubber, between that point and where it enters the bottom of your radiator, cut and insert your tee with temp sender.
The body of your sender may need to be grounded; mine did.
I followed anothers idea in a post I found from searching and removed the factory idiot light sensor and installed an autometer metric to npt adapter and just threaded my autometer sender in. Works great, no leaks and very accurate of the real temp as opposed to farther away.
Thanks. I read that many times and thank you 96r50 for the pics of oem adapter. Nice detailed write up though. I thought there were another thread besides the one link you provided.
