Trans “dropping” while sitting at red lights
Alabama
So this has happened 3 times in the past week. Never had ANY trouble out of my trans, and beyond this problem in the past week it’s never acted up, shifts smooth and on time thru every gear.
Anywho, problem has happened 3 different times, doesn’t happen everyday, but the 3 times it has happened have been extremely similar scenarios that I can’t seem to recreate. Vehicle is a 1996 FZJ80 with auto trans, 153k miles, 35” tires , drive flanges in great shape.
On the drive to work (round trip is only about 6 miles) i stopped at a redlight about 3 miles away from home (truck is fully warmed up at this point) and sit for about 15 seconds. Go to accelerate when the light turns green with very little throttle. Truck doesn’t move AT ALL (actually rolled backwards about a 8 inches) revs to about 1,100-1,300 RPM, slams into gear and takes off. Immediately after this the truck drives normal, doesn’t slip in any gear, shifts on time and smooth just like when I acquired it. Dipstick is showing 1/8th from “full” at the cold/hot mark depending on when i check it obviously. No fluid is mixing in the rad, and the fluid on the dipstick looks brand new (changed fluid about 5,000k miles ago when baselining).
Is this a possible servo issue or am I in for a rebuild? From what I’ve read servos help shift from gear to gear and have little to do with the trans staying engaged but I’m hoping i read that wrong. But, I’ve had a beater with a slipping trans before and this doesn’t feel the same whatsoever. Anywho, I’m clueless when it comes to transmissions, any tips would be much appreciated.
Verify that the fluid strainer inside the transmission is clean enough to pass fluid. The strainer is a simple metal screen that can usually be cleaned and reused.
Also, check the ecu for archived transmission trouble codes which may point to faulty wiring or a solenoid that’s going bad.
You will need a Toyota factory service manual too.
Is it an up hill stop? I have had something similar but after being parked on a steep up hill going from reverse to forward. I over fillled a hair and seemed to help but occasionally/couple times a year still does it. I’ve got 260k of abuse for the last 30k with the Cummins. Playing with 2nd gear lock up low stall converters and 2 broken flex plates.
Edit. Over fill = 1/2 quart added after on the fill mark when hot 15-20 miles of driving running in gear with parking brake and blocks or some one holding brakes. Some people say neutral works too.
