Tranny ?
Yes. You can even use the mounts on the '74 4 speed bellhousing.
Bolt up? Yes?
Shifter levers in different positions? Very much so.
Loss of e-brake? Definitely.
Much shorter rear driveshaft? Abbo-lute-ly!
You don't voluntarily give up that much drivetrain room in a 40 unless you are picking up more gears. My .02.
65swb45 said:
Bolt up? Yes?
Use the tranny top plate of the '74 4 speed tranny. They bolt up no problem. It'll put your tranny shift lever in the same spot as the '74 tranny. I don't recall how close the transfer gets but it's easier to modify as it's all linkages anyways.
There are drive shaft e-brake kits sold for the split case. I think SOR has them. You could also use a post '80 '40 series rear axle with integral e-brake.
