Tranny troubles! help please!
Tamuning, Guam
Went trailing the other day and ended up stranded in the trails till the next day. Spent time makin friends with deep mud, mosquitoes, and warm beer. Anyways my clutch slave pumped out all its fluid but i was still able to put the tranny in gear. Although i was able to put it into gear it felt as if it were in neutral. Then i thought maybe the T case was in neutral but that was not the case, i was still in 4wd. i checked the linkage and it was still in good workin order. a friend of mine told me it might be the pressure plate since none of the gears were "catching". As of my opinion i don't know what the hell is wrong with it. haha. would like to have more opinions before i end up spending a s*** load of cash and going under some major labor action for nothing. ;)
If you use your clutch in mud, the disk may become contaminated with mud and lose its frictional coefficient.
Take off the inspection cover, step on the clutch pedal and power wash between the disk and the pressure plate and flywheel to get rid of the contamination.
