Tranny/Transfer Help
Calgary AB.
Website
photobucket.com
I tried to pull the transfercase Saturday and couldn't get it off alone so I droppped the transmission as well. I replaced the seal between the two and a bunch of gaskets. Things seemed to go well until I drove it. Now, when ever the drivetrain has no load on it, while shifting or coasting etc. there's a rattling/squealing sound coming from underneath. It does it with the clutch in or out. It did make the sound much quieter before I pulled it apart but now it's terrible. Any ideas? I thought I was careful and did everything correctly but here I am. Thanks. .....Steve
BTW, 77FJ40 with 2F and 4spd.
Does it make this noise when you are parked with the transfer case in neutral? If so, It is probably in the tranny or transfer case (up to the transfer output shaft). If not, it is more likely after the transfer case output.
Thanks Pinhead and the guy who PM'ed me (I deleted it and forgot the name). I finally figured it out last night after hours and hours of searching Mud and then some playing under the truck. Turns out my driveshaft was out of phase from the time I got the cruiser and I made it worse when I pulled it apart last week. Now that everything is lined up it drives smooth as silk and the rattling/squealing is gone. Thanks for your help.
May I suggest adding the driveshaft phasing info to the FAQ? It's not in there but I imagine it's a common issue that was only fully explained, including a drawing, in one post I found after searching hundreds. .......Steve
Send me the link.....
:beer:
