Tranny re install.
Escondido CA
Been working hard to get the front of the motor back together after doing both pan arches and both main seals. Went to put the trans back in and the torque convertor is touching but the bell housing is like 2 inches away and the torque converter seems to be in all the way. Any ideas from a hack mechanic???
Are you sure the converter is completely seated into the pump? There is usually a second drop if not lined up properly.
I have rotated it a ton... can't get it to slide back any more...super frustrating...:bang::bang::bang:
Yeah...if you put any more pressure than what it only needs....you will almost never get it seated! It is almost a machined fit.
Damned thing is killing my progress to be done by 24th...have to work too
Google "how to install a torque converter." I watched a video where a guy put it on with one hand in abiut 15 seconds. That was of course after I tried to force it and broke an ear off my case. You need the second drop.
I will try spinning it som more to see if I can get it to slide on....:worms:
