Tranny "Drop-Out"?
Somewhere in NJ
Not sure what to call this problem, if indeed it is one, but wanted to search the collective minds here to set my mind at ease.
Yesterday on a six hour drive home, about 2 hours into the drive and while going up a long grade at about 70mph, the tranny seemed to just drop into a strange mode/gear where if I depressed the gas pedal more, the engine would rev up a bit, but there was no "grab" of the tranny and no acceleration. Just kind of went limp; not sure how else to describe this since I've never felt anythying like it before in any vehicle. If I let off the gas, the tranny would again "grab" and I could maintain my speed and/or accelerate. This happened twice in a span of about 15 seconds, then it stopped doing it and everything went back to normal for the remainder of the trip.
Fluid level is fine with no signs of burnt fluid, no CEL or lights, all gauges look fine.
I seem to recall threads mentioning transmission solenoids and thought I may be starting to have a problem with one, but a search of the site didn't lead me to anything resembling these symptoms.
I know I'm not giving you much info to go on, but that's all I gots as it was very brief and not reproducible. Anybody ever experience anything like this and/or can think of a cause? If there is some problem lurking, will I do any permanent damage or risk being stranded by using the truck as is?
A couple shot-in-the-dark things to look at:
Fluid level
Kick-down cable
Neutral safety switch connections
Other transmission wire connections
Thanks Dan. Fluid level is fine--checked that after pulling into a service area a few miles down the road after this occurred.
I'll have to dig around to look for the other things. This is one of those issues that would probably be easier to diagnose and repair if the darn thing just broke.:rolleyes:
have you chabged the fluid lately, switched to a different kind of fluid? If so you may have changed the detergency level of the fluid and thus stirred up some latent "crap" in the trans. I had a similar scenario on a four hour run @ the very end. I started to loose transmission hookup, with in 10 minutes of getting off the highway I had lost my trans.
Drop the pan ASAP and check to see if there is "crap" in the pan, If so start hunting for a tranny
Good luck
