I drained and replaced all my drive train fluids last night - diffs, transfer case, and tranny. Drove it to the post office today to send Uncle Sam his $$. I noticed a slight drip under the rig on the way out. It was coming from the tranny. Got it home, checked everything - seemed OK. Fluid level was fine. I looked around a bit, and noticed that the gear oil seemed to originate from the top of the tranny and then roll down the sides. Felt around up there, without pulling the tranny hump (PITA). I'm pretty sure, pretty much positive, that the oil is coming out thru the breather vent on the top.
What would cause this ? Tranny getting too hot ? Too much gear oil ? Bad breather valve ? You can only put so much in, I wouldn't think that overfilling is an easy thing to do. I only filled it to the fill hole w/ 80W90.
Any ideas what might be causing this ?
Oh yeah, stock 3 SPD Tranny.
