Tranny and t-case rebuild kits
Does anyone know where to get rebuild kits for my h55 and t-case. I am getting more and more gear/bearing whine and want to rebuild.
Also if anyone has any insight into the whole process any info would be great.
Yes I know to get a FSM.
Where are you located?
Do you have access to a good workshop (for speciallist tools, etc)?
located in vancouver BC and I have a whole mechanics shop at my disposal.
Anyone?
is it possible to buy bearings there off part numbers like this?
Reply
Page 1 of 2 1 2 >
Thread Tools Search this Thread Rate Thread Display Modes
Old 02-11-06, 06:54 PM #1
bigbrowndog
IH8MUD Addict
bigbrowndog's Avatar
Gearbox /Transfer case part numbers for HJ75
These are the bearing part numbers from my gearbox transfer case rebuild recently.These are the numbers off the Koyo Boxes.Hope they help some of you guys source some parts locally.
Koyo.. 6308nrc3..B0508
TR070902 70424 PZ80403
RNU080821NR 70182 PZ00505
DG3580ACL 70285 B0503
30307JR-4
06NUP0820 ANR502C3 70205 PZ-00506
38VP5243 2 off
6207C3M0402 x 2 off
45TKD10 RTC545A
Toyota Bush RTC545A
3342160060Xcluster 5 sp 10/85 7/97
3331160121Amg/box imput shaft hj75
3333660010AMgear small 5th
3333360030X 3rd gear
3334336020 Bush
9099973089Am t/fer gea/bush
3337120010G/B syncro springs
3339136010 sync/sp 5th gear
3336636020 G/B syncro keys
3336820012Rings syncro
3620360050AM Hi/LO 5 speed.
bigbrowndog is online now Edit/Delete Message
Thanks for the list BBD. I am hoping that it will be just bearings but I am not sure till it comes out. Are all the gear parts readily availiable from toyota or do they have to be ordered. Also I see you listed syncro parts how often have you or anyone replaced these? i am trying to see what people have had to do when doing a rebuild. I.E. everyone ends up replacing gears or the opposite.
Hokey dokey chief, as far as I know any of the couple builds I have done none of the synchros need doing.... althought I have set of factory units sitting here.
First rebuild is a bit tough if never tackled, nothing to loose sleep over but a few pointers sure would help.
Tools are essential, specially the right ones to make it easy.
If you do not have these tools either see Rob Milson in VAncouver who has done many trans and tee cases or me who prolly has not time to do one at his point.
My idea on that was, the syncro rings had many years wear against worn gears.Then replace most the gears and the syncro rings then do not match the gears do they.Also the syncro's are cheap compared to the cogs and shafts. My box had no noises of any kind previous to rebuild.
